Programming P89V51RD2
hi to all As i am startd working with P89v51rd2.i am facing some problem some chips are burinning properly and some are not i am uaing ALL-11C2 universal programmer to programming the controller As there is no problem in H/W as some IC's are working properly but some are not i placed the user code on block 0. as i shifted from 12 CLK to 6 CLK at ALE i am getting 4 MHz and 8 MHz Freq respectively. Crystal is 24 MHz .so i think there should not any problem with programmer with this i am attaching the code please guide me where is actual problem.
#include <P89V51Rx2.H>
#include<intrins.h>
#include<define.h>
volatile unsigned int TimeTick1ms;
void TMR_1(void)interrupt 3
                   TR1 = STOP;
                   TL1 = COUNT_LO_1mS;
                   TH1 = COUNT_HI_1mS;
                   TR1 = RUN;
                   TimeTick1ms++;
                   if(TimeTick1ms & 0x01)
                                  {P1 =~P1;}
                  if(TimeTick1ms >= 100)
                                   TimeTick1ms = 0;
                                   P3 =~P3;
void main(void)
                 FCF  = 0x01;
                 //FST  = 0x00;
                 P0   = 0x3f;
                 P1   = 0xff;
                 P2   = 0xf8;
                 P3   = 0xff;
                 IEN0 = 0x88;
                 TMOD = 0x11;
                  TH1  = 0x63;
                  TL1  = 0xBF;
                 TR1  = RUN;
                 TimeTick1ms = 0;
                while(1)
                         P2 =~P2;
                         P0 =~P0;
