ARM RTX snprintf() floating point task.
snprintf() does not appear to work with floating point format within a task. Appears to work normally from main().
Please advise why, and what other functions may be affected similary?
I modified a 'blinky' project and observed the fault under simulation, single step, watch memory 'buffer'.
Seems to work ok if called from main.
char buffer[100];
void
test1(void)
{ float f;
f = 3.14159;
snprintf(buffer,100-1,"%f",f);
/* HELP!!!!! contents of buffer are now '0.000000' , should be '3.141590' */
} /*---------------------------------------------------------------------------- * Task 1 'phaseA': Phase A output *---------------------------------------------------------------------------*/
void phaseA (void) __task { for (;;) { test1(); os_evt_wait_and (0x0001, 0xffff); /* wait for an event flag 0x0001 */ IOSET = LED_A; signal_func (t_phaseB); /* call common signal function */ IOCLR = LED_A;
