I'am using a Ethernet-DK eval board and the TCP-IP configuration wizard from Silicon LABs.I can compile and link without errors or warnings but I can't download it.I get a messagebox"Code edit has been cancelled" and in the output window i see : Build target 'Target 1' compiling netfinder.c... compiling main.c... compiling mn_callback.c... compiling mn_vars.c... compiling index.c... linking... Program Size: data=18.1 xdata=5957 code=35537 "Ethernet_DK_New" - 0 Error(s), 0 Warning(s). Load "D:\\binpc\\eTHERNET_dK_NEW\\Ethernet_DK_New" Flash Erase Done. *** Error: Flash Image Update Failed at FF000000
