Problem accessing USB-host controller when RT-lib is running
I'm having some trouble working with the usb-host controller of an AT91SAM9261 mcu. The CPU stops executing my code if I try to read from the usb-host (address 0x500000). When the mcu crashes it doesn't seem to be jumping to any of the exception-handlers and if I try using the debugger I get an error message that the debugger is "unable to halt the cpu", and then the Debug-message-window is flooded with error messages.
It seem to be related to the RL-RTX library since it seem to work better (it still crashes in certain cases) if I comment out the os_sys_init()-function and don't start the threads.
Does the RL-RTX-lib protect some memory areas or maybe overrides an exception vector or something that might cause this behavior?
I would appreciate any help or suggestions.
Best Regards
/Ake Forslund
