question on memory models
Hi
I have following test code:
#include "C8051F300.h"
void print(char code *inData){
         inData = inData;
static void printVersion(void){
        char code s[]  = "This is a test.";
        print(s);
void main (void){
printVersion();
If I use the memory model "Small: variables in data" this little piece of code works just fine. If I change the memory model to "Large: variables in xdata" it does not work. In printVersion() 's' points exactly on the 'T' in the CODE memory but if I call "print()" the pointer inData is pointing somewhere else in the CODE memory space. Why is that?
Hans
  • In printVersion() 's' points exactly on the 'T' in the CODE memory but if I call "print()" the pointer inData is pointing somewhere else in the CODE memory space. Why is that?
    Probably the compiler hasn't generated any code for inData. If you want to force it to do so declare inData as volatile.
