question on memory models
Hi
I have following test code:
#include "C8051F300.h"
void print(char code *inData){
         inData = inData;
static void printVersion(void){
        char code s[]  = "This is a test.";
        print(s);
void main (void){
printVersion();
If I use the memory model "Small: variables in data" this little piece of code works just fine. If I change the memory model to "Large: variables in xdata" it does not work. In printVersion() 's' points exactly on the 'T' in the CODE memory but if I call "print()" the pointer inData is pointing somewhere else in the CODE memory space. Why is that?
Hans
