I am trying to look for example code to run a tcp/ip stack to run on the eval kit AT91SAM7X256 using Keil. I can find examples using IAR and GNU - but not for Keil...
Any ideas...?
Thanks Marcus.
version 3.60 of microvision has an example called EasyWEB for your board. is that not what you need?
I have uvision 3.12a...
is there anyway I can get hold of this project ?
m
maybe if you download and dummy install the evaluation version...??? I'm not sure but I that will do it.
you must have read my mind - i am about to try it ;)
m.
No joy.
EasyWeb does not exist for the AT91SAM7X board !!
Any help would be gratefully received...starting to sweat a little...
regards m
then how come I have it under
Program Files\Keil_ARM\ARM\Boards\Atmel\AT91SAM7X-EK\EasyWEB
? did you install the latest version?
I dont have that in my program files. Is there anyway of me getting hold of that project...?
thanks m
