I created a project with uVision3 and added all the necessary header files into the file group 'Header' by using Project - Components, Environment, Books. By compiling this project I got many similar errors like:
can't open file '*.h'
It seems that the header files cannot be found. Is this way to include the header files correct?
You don't need to add the Headers to the project - because the headers do not need to be separately compiled!
Just add the source files, and they will find the necessary headers...
If the headers are in the project directory - or the #include statements specifies which absolute or relative directory they are in, with relation to the source files. Or you have specified extra directories to search for include files.
You're right - I oversimplified that!
The full detail is, of course, here: http://www.keil.com/support/man/docs/c166/c166_pp_include.htm
"...similar errors like..."
is far too vague.
To be able to diagnose the precise cause(s) of your particular problem(s) you need to copy-and-paste the full text of the complete message.
It will probably look better if you post it as for source code - see the instructions above the message entry box: www.danlhenry.com/.../keil_code.png
