Access Violation
Hi!
I have the lucky task of debugging a C application whose creators have disappeared and left no documentation. When I run the UV3 debugger in simulation mode, I receive an error message :
access violation at C:0xFFF0 no execute/read permission
This occurs because a subroutine directly calls this
area in memory
__API_FLASH_ENTRY_POINT:
  PUSH  AR2
  PUSH  AR4
  PUSH  AR6
  LCALL 0FFF0h
  POP AR6
  POP AR4
  POP AR2
RET
But when I look in the memory map this area is not defined as exec/read. If I reset and then add this area
to the memory map manually, and then run, everything works OK. I don't want to have to load this for every run. Why isn't it being loaded into the memory map by the linker? Any idea why they are using address x'FFF0'
as the flash entry point? Thanks.
