I KEEP GETTING FATAL ERROR WHEN I TYPE A51 AT MY COMMAND LINE.
I GET TERMINATED.
WHY?
Your shift key seems to be stuck. But I digress.
When you type only "A51" at the command line, you run the A51 assembler - without telling it which file to process. Since there is nothing meaningful for it to do, it prints an error message and exits.
What exactly are you trying to accomplish by running the A51 assembler from the command line ? Usually, the assembler is called by the IDE. Except for experimentation, there are very few reasons to actually run the assembler "by hand".
HOW DO I GET ULTRAEDIT TO DO IT?
TNAX FOR YOUR HELP EVERONE
I FOUND EDITOR CALLED TEXTPAD, I GIVE IT A TRY NOW
I wish you luck. If you read the manual for textpad the same way you read posts here, I suggest you go buy a broom.
It doesn't matter how many editors you try.
Keil most probably have the only editor with built-in integration for the assembler. With any other editor (even if it has code folding) you will fail to integrate the Keil tools. Then you will post that the editor is buggy. Then you will start looking for another editor.
How many weeks will this continue? With a better focus, you would have managed quite a lot of actual development by now.
LEVIT ROON,
If you try TEXTPAD and consider it buggy, I suggest you look here for a few others alternatives:
www.nonags.com/.../texted32.html
If all of these are BUGED, maybe you should just google for 'text editor'. You'll find a lot more to try.
Please don't feel obliged to post your findings for each and every one of them here.
If all of these are BUGED I'm sure they are, they will all have the "bug" that if you do not follow the instructions, they do not work.
I'm sure they all are, they will all have the 'bug' that if you do not follow the instructions, they do not work.
"I'm sure they all are..."
Almost certainly - But it may take him quite a long time to check each and every one before shouting out here again with his utter nonsense ;)
not a futile hope, I hope.
www.milinkito.com/.../bart.php
HI AGIAN,
I TRY TEXTPAD BUT IT IS VERY RUBBISH!
I GO FOR ANOTHER NOW.
TAHNKS FOR ALL YOURH ELP AND SUPPORT
I hope you're enjoying your exercise in futility.
I DONT KNOW WHY U ASK PERSONAL QS??
I LIKEE XERCISES IN FERTILETY!
exercises in fertility - sounds interesting :)
This forum draws trolls like iron cuttings to a magnet. Now and then also a real fool. Alas, it is impossible to distinguish between fools and trolls.
Is it necessary to distinguish them?
No, in reality there should not be a need to be able to distinguish them. But I always have this little hope that it is possible for a fool to suddenly open their eyes and see the real world.
The problem with trolls is that they are intentionally stupid - or provocative - which just makes them a different kind of fool.
It all goes back to the saying: "When you're arguing with a fool, make sure he isn't doing the same thing" or the probably more modern rewrite "Arguing with a fool proves there are two."
