Dear sir;
I am doing an automotive project in LPC2368.Here It uses CAN for making communication between the nodes .The bit rate for both TX and RX is at 500KBits per second.
I configured a network consisting of two transmission nodes and single reception node.If I transmit with 12 data from "CAN_Send_Data" buffer like
while(1) { pCAN_Send_Data = CAN_Send_Data; for( i=0;i<12;i++) { Return_Value=lpc2000CANdriver_CertainTxBufTransmitMessage(LPC2000_CANCHANNEL_1,pCAN_Send_Data,LPC2000_TXB_1); pCAN_Send_Data++; } }
In the receiver I am not getting all data from transmitter.If I put the delay I am getting most of data in Receiver.I am putting delay as shown below,
while(1) { pCAN_Send_Data = CAN_Send_Data; for( i=0;i<12;i++) { for(j=0;j<200000;j++); /*delay for making Receiver to proccess data*/ Return_Value=lpc2000CANdriver_CertainTxBufTransmitMessage(LPC2000_CANCHANNEL_1,pCAN_Send_Data,LPC2000_TXB_1); pCAN_Send_Data++; } }
Will you please tell me ,How I can transmit a data from transmitter in order to achieve 500KB per second(with or without delay) ,such that I can receive and proccess(printing in UART0) all data in the receiver.
Sincerely Shamsudheen OP
look at the errata sheet of the lpc2368. There's a bug with the CAN controler. I don't knwo if it's related to your bug , but it can help :)
