We are using 8.05a of the CX51 compiler. Our program is over 300K long. The compiler times are getting rather long. About 2 minutes. Can the compiler make use of a dual processor to speed up compiling? What is the recommended computer to use? I realize that more RAM helps but after so much it may be irrelevant.
300K size??? what are you doing with that much of size?
May be some problem with OS. May be some virus. Clean Install your OS then check again.
2 minutes? - Luxury!!
When I were a lad, we used to dream o' getting a single file compiled in 2 minutes - let alone a complete build!
