Hi All,
I am trying to interface a simple 4x3 keypad i have never used 89C2051, i am using port 3. The pins i am using are p3.0,p3.1,p3.2,p3.3,p3.4,p3.5,p3.7
this is the basic code i am using
unsigned int keyData() { unsigned int i,j; P3=0xf0; i=P3; P3=0x0f; j=P3; return (i+j); }
call
switch(keyData()) { case 55: // Key 1 LEDR = 1;BUZZ = 1; key_delay();key_delay(); goto start; break; . . .}
I am considering p3.6 =0; i have put two pull ups to p1.1 and p1.0 i was told to do so when i asked my problem to a person i know.
i do not understand the working of the AIN pins may be that is where i am going wrong.
Please help.
Thanks, Ajay
This is a re-post of http://www.keil.com/forum/docs/thread10689.asp with minor corrections.
Thanks for the note Neil.
Ajay
Then it is simple. Always mask away that bit before processing the data you read from port 3. Then you don't have to care about the current output value of the comparator.
Hi Per,
will try that.
Thanks Ajay.
