I take it using sizeof() on a array that is unbounded is a problem (I am getting sizeof returns size of type 0 warnings).
I have defined a constant array of pointers unbounded IE
#define CCHARPTR code char * CCHARPTR numerous_strings[] = { "string1", "string2", "string3.5" };
If I wished to know the number of entries in numerous_strings I thought I could do this
(sizeof(numerous_strings)/sizeof(CCHARPTR))
Obviously I was wrong since the compiler warns sizeof(numerous_strings) is zero. How can I get the size of this array because I would like to save time in having to write a 'magic' number for the number of numerous_strings. Sounds simple, unbounded arrays seem to be what it has issues with. Suggestions anyone?
I suspect that the strings are placed somewhere in memory and numerous_strings[] contains pointers to the strings.
I've never worked with 8051's, is there a way to to take the size of the array / the size of a pointer?
The attributes may be a bit of a problem here.
However, when getting the size of a static array, you should normally avoid using the element data type, since that is a source of error.
It is better to write
#define NELEM(a) (sizeof(a)/sizeof(*(a)))
If you change the data type of the array from byte to word, the NELEM define will still return the number of elements, without you having to scan through the code for inconsistencies.
