CAN: More than one slave problems
HI,
I am working with LPC2129 with full CAN bus.
I have written a code for master and slave. i am running a heartbeat LED on both of them at a rate 1Hz, and they work fine.
When i connect 2nd slave after having done the appropriate changes, the LEDs on two slaves run on much slower frequency 1/2 Hz. ? why? are there certain registers need to be configured for this issue.?
the code i am using should run the same either with one slave or more.
I am using 1Mbps baud rate...
