Hi, Who initializes xxx variable?. static data UINT8 xxx=10;
Is it STARTUP.A51?.
http://www.keil.com/support/man/docs/c51/c51_ap_init.htm
Thanks Dan.
But I don't see INIT.A51 in my uV3 project files. I only see STARTUP.A51. Do I need to copy INIT.A51 to uV3 project explicitely?. Thanks, Chiran.
No!
See: http://www.keil.com/support/docs/783.htm
"[Keil] strongly recommend that you do not modify the INIT.A51 file."
