Hi everyone,
I try to use RTA for implementing unit tests. It works well if I run my test without RTX. I use -Block on write- to make sure that I see all messages send from RTA.
When I use RTA in conjunction with RTX, -Block on write- hangs up the system. RTA works if I disable -Block on write-.
I merged the RTA configuration into RTX_config.c as described by Keil.
Any suggestions?
Thank you, Frank
