Branch to function pointer array
Hopefully someone knows...
I'm writing a jump table for a number of functions. The jump table located '__at' a location in memory contains __asm instructions to branch to all required functions defined previously, using "__asm{B func1}", for example.
Some code I am using contains a function pointer array (*funcptr[16])(arg..), and I'm not sure how to branch to it. if I try __asm{B funcptr}, the compiler (uvision3) complains that the "Target is out of range", which is understandable. Unfortunately my asm abilities are nearly non-existent and I'm unsure how to rectify it.
extern void func1(char stuff);
extern void(* funcptr[16]) (unsigned int arg);
void usb_table(void)    __at 0x00002000
   __asm{B func1}                // located at 0x2000
   __asm{B funcptr}        // target out of range
