Hi! In Hello example for 8051 by MCB900 in main() there is: P2M1=0; P1M1=0; Is it ok?? Im reading the datasheet of de microcontroller and i dont understand it, because to configurate the port is using PxM1 and PxM2. Then why is writed these (bold text)?? Thanks
Well, - The chip is P89LCP936. - And only i want to see how can i switch on/off the led P2. In hello example: Write Hello in serial port this is the configuration:
void main() { unsigned int j; P2M1 = 0; P1M1 = 0; SCON = 0x52; /* initialize UART */ BRGR0 = 0xF0; /* 9600 baud, 8 bit, no parity, 1 stop bit */ BRGR1 = 0x02; while (1) { for (j = 0x01; j <= 0x80; j <<= 1) { /* Blink LED 0,1,2,3,4,5,6 */ P2 = j; /* Toggle port 2 pins each time we print */ //printf ("Hello World\n"); /* Print "Hello World" */ printf ("Hello \n"); delay (); /* Delay about 0.2 seconds */ } } }
Why : P2M1 = 0; P1M1 = 0;?????
Let's be a bit more specific: Have you read the chapter (I think it is chapter 5) in the user manual, where the individual bits of the port mode registers are described?
That chapter tells explicitly what mode the I/O pin will use for any bit combination in P1M1/P1M2 and P2M1/P2M2.
Note that the code only writes to P1M1/P2M1 and not to P1M2/P2M2 so they are keeping their defaults.
Now it should be quite easy to: 1) Figure out what the default values are for P1M2 and P2M2. 2) Figure out what a 0 in P1M1/P2M1 means together with the value of P1M2/P2M2. 3) Decide if that pin mode is suitable for the specific hardware you run on.
The schematics for the board is also available on this web site.
Please come back with specific questions when you have looked through that chapter, looked at the initial value for the 'different SFR and looked at the schematics.
