GNU compiler with assembly coding
Hai all;
I am doing a project in LPC2368 with MCB2300 board.Here,I am doing In application programming by referring from C:\Keil\ARM\Flash\LPC_IAP2_512.After modification this program ,I can write and read from 512k FLASH memory.
This code is working fine in Realview compiler,but when I used with GNU compiler ,one assembly program "IAP.s" showing many error like "bad instruction".
Will you please tell me ,why I can't compile an assembly code in GNU compiler.
sincerely
shamsudheen OP
  • "This code is working fine in Realview compiler"
    You mean the Realview Tool-Set.
    The Tool-Set consists of more than just a Compiler - it also includes the Assembler, Linker, etc.
    See: http://www.keil.com/product/devproc.asp?t=arm&h=1
    "why I can't compile an assembly code in GNU compiler"
    You can't Compile any Assembly source in any Compiler!
    A Compiler cannot translate Assembly source code - you need the appropriate Assembler for that.
    The 'C' language is standardised; Assembly is not.
    Therefore it is highly unlikely that any assembly source written for one assembler will be compatible with another.
