Compiler Errors
Hi there, Iam using Keil uVision3(MDK 3.11) with GNU compiler for my LPC2368 based project.
Iam seeing the following error (undefined reference to '__udivsi3') and warnings( missing braces around initializer) :
Build target 'MCB2300'
assembling Startup.s...
compiling LPC2000_CAN_Driver.c...
src/LPC2000_CAN_Driver.c(72): warning: missing braces around initializer
src/LPC2000_CAN_Driver.c(72): warning: (near initialization for 'CAN_Send_Data[0].DataField')
compiling target.c...
compiling irq.c...
compiling LPC2000_CAN_SYS.c...
linking...
lpc2000_can_sys.o(.text+0x21c): In function 'uart0_config':
src/LPC2000_CAN_SYS.c(225): error: undefined reference to '__udivsi3'
collect2: ld returned 1 exit status
Target not created
The error message points to the code line
"temp_uart0 = (Fpclk/16)/Baudrate; " in the following source code :
void uart0_config(UInt32 Baudrate,UART0MODE U0_config)
  UInt32 temp_uart0;
  U0LCR = 0x80; // DLAB=1, Can use U0DLM, U0DLL
  U0DLM = temp_uart0>>8;
  U0DLL = temp_uart0&0xFF;
  temp_uart0 = U0_config.Datalength - 5;
  if( U0_config.Stopbit == 2 ) temp_uart0 |= 0x04;
  if( U0_config.Paritybit != 0 )
      U0_config.Paritybit = U0_config.Paritybit - 1;
      temp_uart0 |= 0x08;
  temp_uart0 |= U0_config.Paritybit<<4;
  U0LCR = temp_uart0;
  U0FCR = 0x07;
  U0IER = IER_RBR  | IER_RLS;
The warning points to the following code:
lpc2000CANdriver_TXObj_t CAN_Send_Data[] =
{{0x00080000,0x00000001,0x12345678,0x12345678},
 {0x00080000,0x00000002,0x12345678,0x12345678},
 {0x00080000,0x00000347,0x12345678,0x12345678},
 {0x00080000,0x000003F1,0x1643F6E5,0xD4C3B2A1}};
I have observed that, in the Linker settings if the
option "Donot use Standard system libraries" is not selected then the error is not reported by the compiler. But, the UART doesnot work.
I have tried out the same program using Real View Compiler and it works fine.
Kindly give me your suggestions.
  • But, the UART doesnot work.
    Do you mean by this that printf (or similar) does not output to the UART as expected in your GNU compiler build but does on the RealView build.
    If this is true then the following may be relevant.
    It is up to the programmer to provide implementations of the low-level functions that output characters to whatever is considered stdout on the system. If these are not provided then default ones are used which may not implement anything useful.
    The names of these functions differ between the standard libraries used by RealView and the GNU compiler. You probably need to provide an implementation for the GNU compiler.
    For the GNU compiler
    int putchar(int ch)  __attribute__ ((used));
    int getchar (void)  __attribute__ ((used));
