XC164CS-32 port problems
I'm using the XC164CS-32, 40 MHz, and I'm experiencing some problems with the ASC0 port where it seems that its not synchronizing with the program I wrote in C#. The application I wrote will send out at least 6 ASCII characters, but no more than 9.
#define TIMEOUT_100MS                                   31250
#define EBCMOD0_SETTING                                 0x1820
#define EBCMOD1_SETTING                                 0x003F
#define FCONCS1_SETTING                                 0x0031u
#define TCONCS1_SETTING                                 0x0181u
#define ADDRSEL1_SETTING                                0xB000u
#define PORT1_HIGH_DIRECTION_SETTINGS   0x0F
#define PORT1_LOW_DIRECTION_SETTINGS    0xFF
#define PORT3_DIRECTION_SETTINGS                0xB620
#define PORT4_DIRECTION_SETTINGS                0x00FC
#define PORT9_DIRECTION_SETTINGS                0x0001
#define SYS_RDY                                                 P1H_P0
void main(void)
char temp_string[9] = "\0"; char label[3] = ""; int i = 0;
ASC0_FDV = 0x003B; /* load ASC0 fractional divider register */ ASC0_BG = 0x000E; /* load ASC0 baud rate time reload register */ ASC0_CON = 0x88D1; /* load ASC0 control register */ DP1L = PORT1_LOW_DIRECTION_SETTINGS; DP1H = PORT1_HIGH_DIRECTION_SETTINGS;
ALTSEL0P3 = 0x2720; ASC0_TIC = 0x01B9u; ASC0_RIC = 0x01F9; DP3 = 0xB620; P3_P10 = 1; P1H_P3 = 0; /* Disable the loopback relays */ ASC0_RXFCON = 0x0607; ASC0_RXFCON = 0x0605; GPT12E_T3CON_T3R = 1; /* Start the timer T3 */ printf ("Initialized\n"); setup(); update();
        while (1)
        if (GPT12E_T3 > TIMEOUT_100_MS)
                        GPT12E_T3 = 0; /* Reset the timer */
                        update();
                  // if ( (ASC0_FSTAT & 0x0F) != 0)
                if ( (ASC0_FSTAT & 0x0F) > 6)
                    gets(temp_string, 9);
                        if (strcmp(temp_string, "status") == 0)
                                printstat();
                        else if (strlen(temp_string) < 8)
                                printf("sync error. purging RX buffer...\n\n");
                                for (i = 0; i < 100; i++)
                                        ASC0_RBUF = 0x0;
                        else
label[0] = temp_string[6]; label[1] = temp_string[7]; label[2] = '\0';
printf("\nInput: %s \n", temp_string); printf("\nhex label: %s \n",label);
if (strcmp(label,"38") == 0) { // some code }
if (strcmp(label,"72") == 0) { // some code }
if (strcmp(label,"8A") == 0) { // some code }
strcpy(label,""); ASC0_RXFCON = 0x0607; ASC0_RXFCON = 0x0605;
My problem lies in the following IF statement:
if (ASC0_FSTAT & 0x000F) != 0)
For some strange reason, it's not getting the first two characters that I send to it via RS232 and it seems to be some kind of synchronization problem.
I thought I would change the situation by replacing the != 0, but when I try making it greater than 6 (> 6), it will hang and will no received data is coming in.
Does any one see a problem and can help me out?
Steve
