hello to all !!!
I am using ADUC841 and i want do sent a string in that format (8 bit ,1 stop bit, odd - parity) I am writing in C51
how can i set the my MCU to output this string with parity ?????
how i a setup the UART to send with parity ???
my program
void main(void) { T3CON = 0x86; // Configure the baud rate 9600 T3FD = 0x08; SCON = 0x52;
printf("hello"); // the string i want to set with // odd pariy }
thanks in advance to the helpers
mayer
Dude, I am not a C51 guy, ok? But I have done exactly the same thing for an STR9 just yesterday. You know how? I read the manual and configured my UART appropriately. It works like magic! Conclution: Read the manual and it will work like magic for you, too !
In this case, "The Manual" means the Datasheet for the particular chip you are using.
For technical details applicable to the 8051 architecture in general, study the so-called "bible" for the 8051:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
The Keil manuals are here: http://www.keil.com/support/man_c51.htm
And here are some other introductory & reference materials: http://www.keil.com/books/8051books.asp www.8052.com/books.phtml www.8052.com/tutorial.phtml
