hi, im an 8051 noob and trying to run this example program supplied by ARM for students;
AREA eval_proj, CODE ENTRY LDR r1, =0x03FF5008 ; r1 = IOPDATA address LDR r3, [r1] ; r3 = memory[IOPDATA] LDR r2, =0x10 ; r2 = LED offset AND r3, r3, #0 ; r3 = 0x0 (light LED0) Loop LDR r5, =0x0500000 ; r5 = delay counter STR r3, [r1], #0 ; IOPDATA = r3 B Delay Resume ADD r3, r3, r2 ; add offset ADDS r4, r3, #-256 ; if r3 = 256 BNE Loop ; done SWI 0x11 ; terminate program
Delay SUBS r5, r5, #1 ; delay loop BNE Delay B Resume END
the program compiles but i keep getting the error:
eval_proj.axf: Error: L6320W: Ignoring --entry command. Cannot find argument 'Reset_Handler'. eval_proj.axf: Warning: L6320W: Ignoring --first command. Cannot find argument 'Reset_Handler'.
although one is a warning the file is not linking and therefore i cannot debug it. i think i need to change something in the configuration
help please! chris!
hi... i also getting the same problem in ARM.... can_rx.axf: Error: L6320W: Ignoring --entry command. Cannot find argument 'Reset_Handler'. ... how to solve this one....help me..... thanks sakthi
