Moving Message Display with AT89C2051 and Led Dot Matrix
Hi 'sos',
I'm attached two zips here but you cannot to see beacuse you don't have posts enough yet. You must have min. 25 posts to get a status "Junior member". After this you can see and download the attachments in posts and can to search here.
However, I post now a PM to your email address with my projects as attachments.
Please read carefully the original article from ELEKTOR (included in PDF form in the first zip).
Hope this helps for begin.
Do you have a Proteus v7x installed? If not, you can it download too.
thanks sir ihave download zip file from email
and i also have proteus v7x thanks again
I'm working with it only. I recommend the v7.1 sp2...
The AT89C2051 what I'm using is 8051 compatible.
zuisti
