accessing local "c" variables in inline assembly
How do I access a local variable in assembly?
I have used the SRC to determine how the compiler created the variable. it changes it's name from variable to variable?nnn where nnn is a number.
How do I determine what nnn is? (other than looking at the .src file)
can I access the variable using the original label name?
If I use the variable:nnn , nnn will occasionally change and ten I get errors!
Help
