i cant get the program to work. what is wrong?
add-number ( integer a; integer b ) ( add-number = integer a + integer b )
For a start, that isn't a program - it's just a small snippet from a program.
Also, as already noted, it isn't in any programming language supported by Keil tools - so this is the wrong place to ask about it (especially without even stating what language it is supposed to be).
What is it supposed to do? How have you determined that it "doesn't work" - what tests have you conducted? have you thought about any error and/or warning messages that were given?
Again, as already noted, if you're intending to write a program in the 'C' programming language, then you really need to go right back to basics, get a decent textbook, and start at chapter 1.
send code now to nsmerz157@hotmail.com
Simple answer - NO
There are a number of reasons for this simple response. The most fundamental is:
WE DONT HAVE A F&%!@~G CLUE AS TO WHAT CODE YOU ARE AFTER!
