In start.a51, there is defined a idata segment ?STACK.
?STACK SEGMENT IDATA
Now, in my asm file, I want to use the ?STACK to reset the SP,when using it directly as follows,
mov SP, #STACK-1
but there is an error: "error A45: UNDEFINED SYMBOL"
How can I do it, thanks.
Exactly why do you want to reset the stack?
Note that it doesn't work if you reset the stack pointer when you are somewhere in a C routine that later expects there to be information to be popped.
As the limit area of stack, I store the stack when access the ISR. So, I need to renew SP, and at the end of ISR I'll get back the SP.
That strongly indicates you're doing way too much inside that interrupt service routine. ISRs should never use so much data (or call other functions) that their stack usage becomes a burden.
