how to return from FIQ ISR in assembly?
I am writing an assembly FIQ ISR using GCC complier. I want to change return address in FIQ ISR so that after ISR, it returns to the requested address. the reason for doing that is because i am writing a RTOS.
what are the instruction for ISR return in assembly? is it
 SUBS PC, R14, #4
? i know in 8051, noraml function call return is RET, ISR return is RETI.
  • Look at the assembler output of the compiler to see what instructions that are used by fast and normal interrupt handlers.
    Remember that a RTOS doesn't just switch return address - you have to switch to a different stack and make sure that all registers (and other important thread states) gets restored to the values of the other task. That can be quite a lot of hard work, if you are not familiar with the processor instructions.
