Intrp Issues (when relocating)
Hi Ppl.
I've been muddling thru a whole slew of problems with a bootloader.
The biggest pain in my @$$ is that anytime I try to relocate the interrupt vector, interrupts dont work.
I simplified everything down to a single test project. UART and TMR3 intrps.
Original Intrpt and Prog Start specs (0x00) works fine, but anytime I attempt to relocate my project. They simply dont work.
I follow the KB thread about relocating in C changing the required 3 settings:
Int Vect change, startup.a51 change, and CODE SPACE linker change for my prog.
Any ideas why?
Additionally, when getting back to the bootloader proj:
Can i compile the 0-0x1000 BOOTLOAD with NOINTVECT if I use no intrpts and at the same time, be able to reprogram interrupt table with the bootloader?
Chris
