Ive tried to move data from Sbuf to Acc..... Ive tried using this code... whil;e debuggin the code ive used the serial window to pass data.... my main aim is to compare data that i recieve from the Rxd pin with memory
#include<stdio.h> #include<reg51f.h>
unsigned char c ;
char getchar() { while( RI != 0 ) { c = SBUF; RI = 0; } return(c); }
void main() { unsigned char b; b = getchar(); //printf("%c",&b );
B = b; }
ive also tried using _getkey().. and getchar directly.
First off: Why would you like to use any accumulator when you are programming in C? Stay with C for a C program, and leave assembler for an assembler program - or at least an assembler module.
Another thing: Are you sure that the getchar() code should look like you posted?
