i2c baud rate
i posted this here now because i am new to this forum and accidentally posted on another thread and got severely flamed.
i use the processor PSD3233QAT-RF
i've got a question about i2c function.
1) is it true that i can set any fixed baud rate (clock) from 0 to 100KHz?
2) if i set the bit I2CFREQ, what value should i put into the register if i'm using crystal 4MHz?
4) if i set the bit I2CFREQ2,SMP=0, is the baud rate fixed to 400KHz or i'm free to set any baud rate from 0 to 400KHZ? what value should i put into I2CADD then using a 20MHZ crystal?
answers are appreciated.
Thank you.
