In example Keil_IODemo.zip program from link
http://www.keil.com/download/docs/245.asp
I guess this uses normal 450 UART baud rate generation for the setting of 9600bps.
Values of Divisor Latch Registers are calculated below: COMDIV0 = 0x93; COMDIV1 = 0x00;
In which file to set the CD (clock divider) bit values in MMR POWCON[2:0] ?
Thanks.
Problem solved myself. Thanks.
