I'm working on a http server using a LPC2129 and a Microchip ENC28J60. It's already functional using the Microchip TCP stack adapted to LPC. Now I'm trying to use the RL-TCPnet and I need to write the ENC28J60 Driver. I'm using the LAN91C111 as base to write the driver. Maybe someone can help me with some tips to how to write the functions, because the controllers are quite different.
I have driver, and can send to your email.
Georg
Send it to me too please (viktor@vittech.com.br)
Thank you
Send it to me too please! (lebiga@mail.ru)
Thank you!
I'm working too on a http server using a LPC2138 and a ENC28J60. I adapted Microchip TCP stack 4.02 to LPC. I have problem - low reliability! Microchip driver is weak...
Thank you...Now it's working. I was trying to use the Interrupt Mode, but I forgot about a silicon bug that I found when I was working on Microchip TCP stack. Sometimes the EIR register doesn't update correctly, so I have to read EPKTCNT before check the PKTIF flag. Because of that I can't use it in interrupt mode. I don't know if it was corrected because my device is at least 2 years old...
