WARNING WHEN USING MICROLIB
Hi all,
When I use the MICROLIB option, I get a warning :
Warning: L6329W: Pattern STRx.o(RO) only matches removed unused sections.
Any idea what could be the reason, and what to do ?
Kind regards
Luc vercruysse
robosoft N.V.
This is the scatter file where the warning
The line that causes the warning is RED
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000         {    ; load region
  ER_IROM1 0x00000000 0x00088000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
    STR91x.o (+RO)
   .ANY (+RO)
  RW_IRAM1 0x04000000 0x00018000  {  ; RW data
    Library.o (+RO)
   .ANY (+RW +ZI)
  • No item in the STR91x.o library was referenced so it was removed.
    To remove the warning you may:
    1) remove STR91x.o from the scatter file
    2) reference an item in the STR91x.o library so it is included.
    3) disable the warning by putting "--diag_suppress L6329W" in the Misc controls of the linker section
