if (0) condition, but entered.
I am using GNU compiler in uVision 3.51. A portion of code is simliar to below:
X = 100; Y = 100; If(x!=y){ Xxxx; }else{ Yyyy; }
By using break point, i found that both Xxxx and Yyyy are entered. It happened in both subroutine, and main. Both X and Y are declared as unsigned integer as global variables. The entire code is less than 16K (about 70% of 16K). Do you have any idea on this? The IC used is LPC2129. Thanks for your advice.
Regards,
