I am writing code that requires a fair amount of pointer arithmetic and manipulation. The C51 compiler appears to generate lots of generic pointers (much too my dismay). Is there any way to use the built in dual DPTR's to reduce the massive overhead associated with generic pointers significantly? The C51 derivative I'm using (MCS12XX) does have dual data pointers as far as I can tell.
I've attempted judicious use of the
#pragma modp2
directive with no visible change in the code output from the compiler. Specifically I am generating graphic information that is sent to a memory mapped graphic LCD. It works just fine that's not the problem. The problem is code space and the overhead that the generic pointers have are going to make things difficult to complete as wished. So is there a way to get around this?
Stephen
The compiler only uses #pragma modp2 for a few string manipalation functions. to reduce the pointer size you can use memory-specific pointers instead.
char * ptr; //-generic char data *ptr //-memory-specific
void func (u8 *pointer) will use generic pointers
a function like void func (u8 xdata *pointer) will use a non-generic XDATA pointer
if you tell your functions where the data is they need not do the generic stuff
I actually often make two copies of a routine like
void RalphX(u8 xdata * data pointer) and void RalphC(u8 code * data pointer)
just to avoid the overhead
here is the skinny
char helloX (unsigned char xdata *ptr) { return *ptr; } char hello (unsigned char *ptr) { return *ptr; } gives ; FUNCTION _helloX (BEGIN) ; SOURCE LINE # 646 0000 8E00 R MOV ptr,R6 0002 8F00 R MOV ptr+01H,R7 ; SOURCE LINE # 647 ; SOURCE LINE # 648 0004 AE00 R MOV R6,ptr 0006 AF00 R MOV R7,ptr+01H 0008 8F82 MOV DPL,R7 000A 8E83 MOV DPH,R6 000C E0 MOVX A,@DPTR 000D FF MOV R7,A ; SOURCE LINE # 650 000E ?C0127: 000E 22 RET C51 COMPILER V7.10 SPUSB 08/03/2007 13:20:28 PAGE 65 ; FUNCTION _helloX (END) ; FUNCTION _hello (BEGIN) ; SOURCE LINE # 652 0000 8B00 R MOV ptr,R3 0002 8A00 R MOV ptr+01H,R2 0004 8900 R MOV ptr+02H,R1 ; SOURCE LINE # 653 ; SOURCE LINE # 654 0006 AB00 R MOV R3,ptr 0008 AA00 R MOV R2,ptr+01H 000A A900 R MOV R1,ptr+02H 000C 120000 E LCALL ?C?CLDPTR 000F FF MOV R7,A ; SOURCE LINE # 656 0010 ?C0128: 0010 22 RET ; FUNCTION _hello (END)
I, usually, do not take the time to do so, but I got curious to see how valid a 'rule' I put on myself years ago (NEVER a generic pointer) actually was.
I found it even more valid than I remembered.
PS the above refer to Keil C51 nothing else, it may and may not be valid for others.
I should have mentioned that LCALL ?C?CLDPTR is the real 'overhead generator' in the example I gave.
First thanks for explaining what was going on with the generic pointers. I guess I didn't tweak on the compiler enough to find out the internal pointer abuse going on. I plan to abuse xdata pointers more.
Indeed Erik that is what I discovered (amongst other surprises). So if I use an explicit pointer in this case it will reduce overhead. The generic pointers have been a killer (sigh) so I plan on doing something like
#define LPTR xdata
and putting that in front of anything that's suffering from generic data pointers horribly. That way if the code goes to a different processor I just redefine that to an empty define and it becomes normal.
