How to see C code when using ULINK2 with Atmel AT91RM9200
I'm using a Keil Ulink2 ICE debugger with an Atmel AT91RM9200 (ARM 9) powered board.
My problem is that it doesn't look like I'm benefiting from all the features of the debugger.
For example, in the Disassembly window, I don't see the C code mixed with the assembly instructions, like in the following picture:
http://www.keil.com/uvision/db_view_disasm.asp
Also, the Debug Settings from the Debug menu is not active.
When I use the simulator from uVision, I can use both of these features. But the simulator doesn't help me too much, as I need the hardware.
Are there some hidden settings in order to fully use the ICE debugger?
