I'm a bit curious as to why this bit of code wasn't AS optimized as it would normally be. I have written compilers, so I am not clueless it's just strange the optimizer didn't optimize out some of this code. This code becomes
ADCON1 = chan->constants.location_info.con1 & 0x70; ADMUX = chan->constants.location_info.mux; ADCON0 = chan->constants.type_info.con0; OCH = chan->a2d.och; OCM = chan->a2d.ocm; OCL = chan->a2d.ocl; GCH = chan->a2d.gch; GCM = chan->a2d.gcm; GCL = chan->a2d.gcl;
this code
0010 L?0038: 0010 L?0039: 0010 F582 MOV DPL,A 0012 E4 CLR A 0013 3E ADDC A,R6 0014 F583 MOV DPH,A 0016 E0 MOVX A,@DPTR 0017 22 RET 0000 8F82 MOV DPL,R7 0002 8E83 MOV DPH,R6 0004 A3 INC DPTR 0005 A3 INC DPTR 0006 E0 MOVX A,@DPTR 0007 5470 ANL A,#070H 0009 F5DD MOV ADCON1,A ; SOURCE LINE # 279 000B 8F82 MOV DPL,R7 000D 8E83 MOV DPH,R6 000F E0 MOVX A,@DPTR 0010 F5D7 MOV ADMUX,A ; SOURCE LINE # 282 0012 EF MOV A,R7 0013 2404 ADD A,#04H 0015 120000 R LCALL L?0038 0018 F5DC MOV ADCON0,A ; SOURCE LINE # 286 001A EF MOV A,R7 001B 2417 ADD A,#017H 001D 120000 R LCALL L?0038 0020 F5D3 MOV OCH,A ; SOURCE LINE # 287 0022 EF MOV A,R7 0023 2418 ADD A,#018H 0025 120000 R LCALL L?0039 0028 F5D2 MOV OCM,A ; SOURCE LINE # 288 002A EF MOV A,R7 002B 2419 ADD A,#019H 002D 120000 R LCALL L?0039 0030 F5D1 MOV OCL,A ; SOURCE LINE # 290 0032 EF MOV A,R7 0033 241A ADD A,#01AH 0035 120000 R LCALL L?0039 0038 F5D6 MOV GCH,A ; SOURCE LINE # 291 003A EF MOV A,R7 003B 241B ADD A,#01BH 003D 120000 R LCALL L?0039 0040 F5D5 MOV GCM,A ; SOURCE LINE # 292 0042 EF MOV A,R7 0043 241C ADD A,#01CH 0045 120000 R LCALL L?0039 0048 F5D4 MOV GCL,A
First all the information is references from a pointer. All variable data access is sequential from said pointer. Why isn't it optimizing out the ADD A, #XXX into INC DPTR? It has done this a number of other places in the code. Why not here?
Do I have the settings wrong or something? Do I need to arrange the code differently?
This is embedded into an ISR could that be the reason (that wouldn't make sense however ... )
If anyone can let me know if I need to do something different.
Stephen
