initializing globals problem
HI,
I am new to the micro controllers , i am initializing the globals but when i try to access the globals in my program i am not able read the data , but when i try to modify the globals in my function i am able to read the modified data , i checked in these forum where i got to know that startup code has to be used, even i tried that method still the problem i persist, and i am using large memory model in my project.
for example
 unsigned char *p = "hello";
 void main()
    printf("%s",p);
where i get "null" get printed .
Regards,
Lokesh Yadav
  • Run it in the simulator.
    If it works in the simulator, then there is most likely something wrong with your hardware and/or your hardware configuration;
    If it doesn't work in the simulator, then your code is fundamentally broken - and the simulator will be the easiest place to find the problem!
