how to declare a xbyte address in the function's parameter?
I has defined some xbyte macro,as belows:
#define PA XBYTE[0XF100]
#define PB XBYTE[0XF200].....
now,i want pass the PA and PB as a parameter of a
function, how to declare them in the function?
if i wrote the function like this :
f(XBYTE * b)
 unsigned char temp;
 *b = temp;
call like this:
f(PA);
the keil's compile will be error.
And if i wrote the function like belows :
f(unsigned char   b)
 uchar temp;
 b = temp;
call also like this:
f(PA);
keil's compile will passed,but the mcu will
not access the extran data RAM, and the RD/WR signal
will not pull low.
HOW CAN I declare a xbyte address in the function's parameter? THANK YOU.
