Is this "Production Utility" available? Has the future arrived?
----- Email sent to Keil on 4/6/07 ----------------- I'm using the Keil ARM Compiler and the ULINK for code development using the STR735 device (I own the product). In another couple of months I should be in production. I was told that I could use the downloaded version in production for programming the parts. But that would exposed the source code.
Is there a product that is available that could be used in production. A windows program where through the GUI, the product name could be selected and the target could be programed through the JTAG. The target name would have to be associated with the device flash file.
What I need is already available in your product. I would prefer to have a standalone program for the production floor that does not expose the Source Code.
------- Response from Keil on 4/12/07 --------------- Currently there is no way to avoid the pop-up of uVision during the programming process. However there will be a utility in the future that avoids that. (Q3/2007).
Reinhard
