Trouble with AT89C51ED2
i have bought a mini-board that has an ICP connection and was trying to program it using keil uvision3. since i use my laptop, i had to interface the USB with RS232, so i used USB to DB9 serial port. First question, i am not sure if the keil would recognize the target board mentioned below through this USB adapter. the second question is for this kind of programming what kind of configuration (flash configuration) in keil software i should use ? what is ULINK ?
kindest regards
