I am using a graphics LCD manufactured by POWER LIGHT i.e,PL G 19264(1A series) Actually when reading data from the data RAM of the LCD,if I read only once from the LCD,it gives erroneous results.But if I read the same data twice consecutively,I am getting the desired result. I am totally unable to understand it needs reading twice though there is nothing written in the datasheet of the LCD.
Please help,urgently!!!
Urgently?
This is not any official Keil support center. This is normal users - just like you.
Anyway - have you checked your timing? You may be too fast. Or you may have problems with slow rise times on a signal.
I have same problem with TOSHIBA LCD T6965H but i sometimes cannot see image
I have read the datasheet of the part but cannot see details of when image shows on the 4 bits below time!
What is wrong?
Per,
Give me your email address and I'll send you my code and datasheets.
I need to have a demo giong by tomorrow, so I'll send it to you immediately.
Remsig
Ehrm. I'm already booked with work until well after my summer vacation. I don't think you would like to pay the charges I would require to perform a night-time panic job... :)
If it is a demo, and you get the data by reading two times, then just read the data two times. A final fix (hw or sw) is only required before starting up production of the unit.
