I am using a graphics LCD manufactured by POWER LIGHT i.e,PL G 19264(1A series) Actually when reading data from the data RAM of the LCD,if I read only once from the LCD,it gives erroneous results.But if I read the same data twice consecutively,I am getting the desired result. I am totally unable to understand it needs reading twice though there is nothing written in the datasheet of the LCD.
Please help,urgently!!!
I have same problem with TOSHIBA LCD T6965H but i sometimes cannot see image
I have read the datasheet of the part but cannot see details of when image shows on the 4 bits below time!
What is wrong?
Per,
Give me your email address and I'll send you my code and datasheets.
I need to have a demo giong by tomorrow, so I'll send it to you immediately.
Remsig
Ehrm. I'm already booked with work until well after my summer vacation. I don't think you would like to pay the charges I would require to perform a night-time panic job... :)
If it is a demo, and you get the data by reading two times, then just read the data two times. A final fix (hw or sw) is only required before starting up production of the unit.
