Hi, Iam getting the following error while trying to build an example Keil project for UART (downloaded from NXP's website).
Build target 'MCB2300 Debug' linking....\Obj\uart_debug.axf: error: L6938E: Invalid value for --ro-base. Target not created
Kindly give your suggestions to debug this error.
"Kindly give your suggestions to debug this error."
The steps are the same, irrespective of the toolchain:
1. Read the message: what is it telling you?
In your case, it is telling you that the value specified for "--ro-base" in your project is not valid
2. Check the Project: what --ro-base value did you specify?
3. Check the manual: what are the valid types and/or ranges of values for --ro-base?
4. Fix the Project: so that it specifies a valid value for --ro-base!
Possible explanation:
Sometimes "valid" --ro-base values for the chip being used are not "valid" while using the evaluation version of the Keil tools.
Thanks everyone for your valuable suggestions. Yes Patrick, you are correct. I also got a confirmation from NXP semiconductors and the linker error is due to the evaluation s/w that Iam using.
