I am using STR750/Keil development kit. The JTAG programmer I am using is ULINK2. uVision3 Ver. 3.0. Today I have problem to download program to the starter kit. It said "Erase Done, Programming Failed!". I've tried two starter kits and same thing happened. Howerever, when I downloaded the program to my custom board, everything is okay. So ULINK2 should work fine.
I don't know what happened to the Keil Board. I checked the voltage, it was 3.3V. Anybody here has the clue. Thanks.
By the way, I tried to operate the UART, but I could not see the signal out from the port. I wonder whether Keil can provide some example codes.
Thanks again. Fei
