error 65 : access violation at.... LPC2148
I hope, that somebody can help me.
I worte a linked list with carm in the µVersion (LPC2148-MCB2140-Board)
Everytime when I start the program the compiler throws the exception
"error 65: access violation at 0x00000050: no 'write' permission"
I read that's because of the pointer of my linked list. The pointers are initialized with NULL. So when I allocate some memory for the pointer, the error is thrown. This is because of the memory allocation in the ROM.
So I tried to solve the error with __ram. I wrote it after the function prototype. But there was no effect.
Do somebody know a solution for my problem?
P.S.: I'm sorry for my english
  • Everytime hen I start the program the compiler throws the exception
    No, the compiler doesn't do any such thing. The simulator does, and some other types of debugging environment may do the same.
    Not necessarily. It all depends on what you mean by saying "I allocate memory for a pointer". Do you allocate memory to store the pointer in, or are you assigning the pointer a value pointing into freshly allocated memory? Or maybe both?
    Either way, most probably you just haven't read or followed the documentation of malloc() and friends closely enough. Now would be the time to do it.
