hi,
i m using an IDE which generates .obj file as final end result.But i want hex file. so is there any converter of object to hex file. please help in this matter.
yes, bin2hex.
but are you sure you have used your linker?
http://www.keil.com/support/man/docs/lx51/lx51_intro.htm
and
http://www.keil.com/support/man/docs/oh51/
-- Joost
yes i have used my linker but it the limitation of IDE to generate only object file as end result.
from where can i download BIN2HEX converter.
http://www.keil.com/support/docs/275.htm
Note that all references cited so refer refer to the Object file format used by Keil - since you seem to be using a non-Keil tool, it may be using a different Object file format.
Be sure to check the applicability to your particular tools!
I assumed Keil tools, on this Keil forum ;-)
"I assumed Keil tools, on this Keil forum ;-)"
Yes - you'd have thought that would be obvious, wouldn't you? And it says it specifically here: http://www.keil.com/forum/
And yet people continually post questions about non-Keil products!
The OP's description of his IDE does not match the behaviour of the Keil tools, so I presume it must be non-Keil?
"Be sure to check the applicability to your particular tools!"
eg, see: www.8052.com/.../read.phtml
Hello Manish,
Just needed the affirmation from you whether you are familiar with the below mentioned e-mail address or name:
>> monnie_20032003@yahoo.com >> sony
Really appreciate that.
-M
to mm tt
i m not familiar with this email id.
What's with the cryptic messages and what does it have to do with this thread?
void fatcheck(vodi) { unsigned char sectors_per_cluster; unsigned int *pi; unsigned long *pl; pi = (unsigned int *)&raw_block[FAT_BYTES_PER_SECTOR]; partition.bytes_per_sector = *pi++; partition.sectors_per_cluster = *pi & 0xFF; pi = (unsigned int *)&raw_block[FAT_RESERVED_SECTORS]; reserved_sectors = *pi++; number_of_fats = *pi & 0xFF; pl = (unsigned long *)&raw_block[FAT_FAT_SIZE]; sectors_per_fat = *pl; partition.fat1_start_sector = partition.offset + reserved_sectors; partition.fat2_start_sector = partition.fat1_start_sector + sectors_per_fat; partition.root_dir_start_sector = partition.fat2_start_sector + sectors_per_fat; partition.last_free_chain = 0; fat_find_free_chain();} static unsigned long fat_calc_data_address(unsigned long cluster, unsigned char sector) {unsigned long offset; offset = ((cluster - 2) * partition.sectors_per_cluster); offset += partition.root_dir_start_sector; offset += sector; offset *= partition.bytes_per_sector; return offset;} static unsigned long fat_calc_chain_address(unsigned long index) {unsigned long offset; offset = partition.fat1_start_sector + (index >> 7); offset *= partition.bytes_per_sector; return offset;} void fat_load_root_directory(void) {unsigned long offset; offset = partition.root_dir_start_sector; offset *= partition.bytes_per_sector; mmc_read(offset); directory.parent_cluster = 0x00; directory.start_cluster = 0x02; directory.current_sector = 0x00; directory.current_cluster = 0x02; directory.current_direntry = (DIRENTRY *)FIRST_ENTRY_IN_ROOT;} static void fat_load_directory(unsigned long cluster, unsigned char sector, unsigned char new) {mmc_read(fat_calc_data_address(cluster, sector)); if (new) {directory.parent_cluster = directory.start_cluster; directory.start_cluster = cluster; directory.current_direntry = (DIRENTRY *)FIRST_ENTRY_IN_DIR;} directory.current_cluster = cluster; directory.current_sector = sector;} static void fat_read_next_sector_or_cluster(void) {if (directory.current_sector == (partition.sectors_per_cluster-1)) fat_load_directory(fat_next_chain(directory.current_cluster), 0, FALSE); else {directory.current_sector++; fat_load_directory(directory.current_cluster, directory.current_sector, FALSE);}} static DIRENTRY *fat_seek_directory(char *name, unsigned char find_free) {unsigned char i; DIRENTRY *p = (DIRENTRY *)START_OF_SECTOR; fat_load_directory(directory.start_cluster, 0, FALSE); i = 0; while(1) {i++; if (match_name(name, p->Name, 8)) if (p->Attribute & ATTRIB_SUBDIR) {if (!find_free) return p; else return 0;} if (!p->Name[0]) {if (!find_free) return 0; else return p;} p++; if (!(i % 0x10)) {i = 0; p = (DIRENTRY *)START_OF_SECTOR; fat_read_next_sector_or_cluster();}} return 0;} static DIRENTRY *fat_seek_file(char *name, unsigned char find_free) {unsigned char i; DIRENTRY *p = (DIRENTRY *)START_OF_SECTOR; fat_load_directory(directory.start_cluster, 0, FALSE); i = 0; while(1) {i++; if (match_name(name, p->Name, 11)) if (p->Attribute == ATTRIB_ARCHIVE) return p; if (!p->Name[0]) {if (!find_free) return 0; else return p;} p++; if (!(i % 0x10)) {i = 0; p = (DIRENTRY *)START_OF_SECTOR; fat_read_next_sector_or_cluster();}} return 0;} static unsigned long fat_find_free_chain(void) {unsigned long index = partition.last_free_chain; unsigned long *p; mmc_read(fat_calc_chain_address(index)); p = (unsigned long* )START_OF_SECTOR; p += (index & 0x7F); while(*p) {index++; p++; if (!(index % 0x80)) {mmc_read(fat_calc_chain_address(index)); p = (unsigned long* )START_OF_SECTOR;}} partition.last_free_chain = index; return index;} unsigned char fat_read_direntry(unsigned char first) {if (first) fat_load_directory(directory.start_cluster, 0, FALSE); else {if (directory.current_direntry == (DIRENTRY *)LAST_DIRENTRY) {fat_read_next_sector_or_cluster(); directory.current_direntry = (DIRENTRY *)START_OF_SECTOR;} else directory.current_direntry += 0x20; }} static unsigned long fat_next_chain(unsigned long from) {unsigned long *p; mmc_read(fat_calc_chain_address(from)); p = (unsigned long* )START_OF_SECTOR; p += (from & 0x7F); return *p;} void fat_mark_next_chain(unsigned long old, unsigned long new) {unsigned long *p; unsigned long offset; offset = fat_calc_chain_address(old); mmc_read(offset); p = (unsigned long* )START_OF_SECTOR; p += (old & 0x7F); *p = new; mmc_write(offset); offset = fat_calc_chain_address(new); mmc_read(offset); p = (unsigned long* )START_OF_SECTOR; p += (new & 0x7F); *p = 0x0FFFFFFF; mmc_write(offset);} void fat_chain_free(unsigned long index) {unsigned long *p; unsigned long temp = index; unsigned long offset; while (temp) {offset = fat_calc_chain_address(temp); mmc_read(offset); p = (unsigned long* )START_OF_SECTOR; p += (temp & 0x7F); temp = *p; *p = 0; mmc_write(offset); }} static void fat_clear_sector(unsigned long cluster, unsigned char sector) {mmc_clear(fat_calc_data_address(cluster, sector));} unsigned char fat_make_directory(char *name) }
Why put this in this thread and not keep it here http://www.keil.com/forum/docs/thread10155.asp ??? And it looks -very- messy.
Whats wrong with this code ? 1) it is not indented 2) it is not commented 3) it is in the wrong thread 4) naah - the above will suffice
