Hello I am using microVision2 V2.40. When I'm trying to open the project file I have a following get this message Can't read project project file 'ProjectFileName'!. Anyone had similar problems?
When do you get this message?
Is it when uVision starts, and tries to re-open the previous project? If so does the Project still exist, and is it still in the same location?
If not, please provide full details of exactly the steps you take, and exactly what happens in each...
This forum doesn't use
tags - the available tags are listed here: http://www.keil.com/forum/tips.asp and shown in the Note above the message window when you make a post.
Remember to use the 'Preview' button to check formatting!
"I go to Project->Open Project and when I select the project file I have that pop up message"
uVision Project files (.uv2 and .opt) are plain text - what happens if you try to open it in Notepad?
I can open it in notepad. It looks like this:
"### uVision2 Project, (C) Keil Software
### Do not modify !
" and so on. So problem is only when I'm opening from Keil.
